Prev Previous Post   Next Post Next
Old 11-12-2024, 08:57 AM   #7
mad2
Regular...with metamusal
Default Re: Ford Falcon BA XT ICC Problem
Originally Posted by arnast View Post
The connector on the firewall has a black surround holding the connector in place i need to move the connector further back as the aftermarket stereo seems to be pushing against it if i remove the black surround to push the connector a bit back is there a risk of it falling behind the firewall?
hi, it won't go thru the firewall as the heater/aircon unit is in the way. before you do that check the depth needed for the new unit against what actual room you have. and that connector has clips holding it in place, just undo clips on either end and it will push back slightly.
